16-24kw burner problems
manniste
9
Tilmeldt: 09 jan 2016 13:35
Senest aktiv: 13 nov 2016 07:35
Re: 16-24kw burner problems
Indlæg af manniste »
Update.
Chimney draft:0
10% flame became stable and without black tips at 17
50% flame stable and with no black tips at 27
100% impossible to set, I was already up to 65 and still massive flame :( and smoke temp went really up, 168C, then I stopped.
Did the changes in small steps and waited 10min and then changed again if needed.
manniste
9
kivi skrev:You can change the kW of the burner in the control box.
If it's a v6 like mine its in menu 4 autocalculation (don't if it's called that).
I believe it's set to 10 kW as default. You should change that to the size of your burner.
Yes, that one is set to 25kw (first couple years it was even 30kw by the company who installed the system). Burner suppose to be 16-24kw.
MHES
Tilmeldt: 17 jan 2007 21:36
Senest aktiv: 17 jun 2018 08:53
Mit fyr: RTB 10 kW
Areal: 250 m2
Fremviser gerne i postnummer: 4180
Årligt forbrug: 5,5 ton
Geografisk sted: Sorø
Indlæg af MHES »
Hi,
When you get to these high values for the fan, something seems to be wrong.
I know you have been asked before, but make sure the fan is running in right direction.
If the fan is running in the wrong direction, it will not make vacuum in the burner, but just be ineffective.
Also make sure that the blades of the fan are clean and the "air way" into the burner is free.
This also includes the holes in the burner grate, make sure they are all clean by putting a drill through each of them.
Your cleaning should be something like every 10 minutes for 4-5 seconds with a fan-percentage of 1,5 x "Fan high".
If cleaning has too high fan speed or the length of the cleaning is too long, the ashes "burn" to cinders.
Michael
manniste skrev:Update.
Chimney draft:0
manniste
9
What should I do to check the fan's blow direction? Take the whole burner out and put it to blow?
The holes in the grate looks like clean and the blades also
Senest aktiv: i går 19:52
manniste skrev:What should I do to check the fan's blow direction? Take the whole burner out and put it to blow?
Yes, take it all off, and look during start.
I suspect bad pellets.
Is it possible to try a completely different?
manniste
9
Update:
Took the burner out. Blower looks to blow in correct direction, into the pipe that leads to the burning grate.
I've been using only high grade pellets... http://www.graanulinvest.ee/eng/frontpage ,biggest producer here.
triumph
Tilmeldt: 02 aug 2011 21:08
Senest aktiv: i går 16:59
Årligt forbrug: 7,2 tons
Har takket: 442 gange
Blevet takket: 474 gange
Indlæg af triumph »
You are shure your burner is set to "AUTO COMBUSTION" (value in auto combustion chould be set to "yes")
Page 7 in the manual
http://sandbox.nbe.dk/wp-content/upload ... nglish.pdf
MHES
Mit fyr: RTB 10 kW
Areal: 250 m2
Indlæg af MHES »
Just to be sure...
...please see attached file for instruction on fan blade direction and correct fitting of the burner grate.
I just go to the basics to be sure we don't miss anything.
Michael
manniste
9
Auto combustion is "YES" and blower blows like attached file shows. And burner grate also like the picture showed.
Just to check again, I pulled the plug from the burner and waited for the blower to stop and then attached the plug to see which direction it will start.
When done that I noticed that after putting the plug back it went to Temp Stop, even when target boiler temp is set to 60C and "over difference" is at 15C and actual boiler temp at this moment was 63C.
I also hope that it is some kind a easy fix somewhere which I haven't noticed yet.
kivi
Tilmeldt: 09 maj 2012 22:28
Senest aktiv: 31 jul 2025 21:05
Mit fyr: Black Star 1016 16 kW
Fremviser gerne i postnummer: 8300
Geografisk sted: Odder
Har takket: 59 gange
Blevet takket: 43 gange
Indlæg af kivi »
That's normal, it wont start until it hits your diff below settings.
Mvh. Ole
