New in Denmark - Solar Heating Question
Spørgsmål vedr. solvarmeanlæg
SamL
Tilmeldt: 21 apr 2019 13:37
Senest aktiv: 23 apr 2019 16:03
Indlæg af SamL »
Hello,
I have just moved to Denmark from England and bought my first house!
The house I bought has Solar Electric Panels and Solar Heating Panels for hot water. When we moved in, the system was working nicely, but now the Solar Heating panels do not heat up my hot water tank...
I have noticed two things:
1. The Sun-Comfort control box now says "Frostsikring" I think this means Frost Protection, but it is now 25 degrees outside and beautiful weather in Denmark.
2. On the pipes I have noticed that one side says 60 degrees and one side says 19 degrees, but I can hear the pump working.
I have attached some pictures.
If any super fantastic Danish person can help a new Brit then I would be very grateful!
I am not an expert with this type of thing just so you know.
I was not given any information about the solar panels and solar heating when I moved in... :(
Best regards,
Sam
Fiffer
6
Tilmeldt: 29 mar 2019 18:14
Senest aktiv: 01 aug 2025 22:57
Mit fyr: Nbe 1016 kedel 10kw
Areal: 140
Dagligt forbrug: 6 kg
Årligt forbrug: 6
Har takket: 394 gange
Blevet takket: 114 gange
Re: New in Denmark - Solar Heating Question
Indlæg af Fiffer »
You Can get help from stokerforum.dk , they have a forum for sunpanels. If it fails to get help here. Best regards
10 kw nbe 1016 kedel,140 kvm hus, murer af Guds nåde.
John Skov Jensen
Tilmeldt: 02 maj 2009 20:40
Senest aktiv: i går 04:41
Mit fyr: Atmos DC40GD
Areal: sammenlagt 350 m2
Brændsel: Bøg
Blevet takket: 468 gange
Indlæg af John Skov Jensen »
SamL skrev: 21 apr 2019 13:51 Hello,
Best regards,
Sam
You have a Suncomfort control unit.
Here is a link to the manual
https://www.nbe.dk/wp-content/uploads/2 ... sion-6.pdf
Only available in danish apparently, sorry
As i see it, your absorber sensor in the top of your panels shows -99 degrees. That indicates a short circuit in the sensor or the sensor cable or "just" a faulty sensor
And this invalid input sets the control unit into frost protection mode
