Fejl F1 in new Scotte - whats the problem? (now solved)
petaas
Tilmeldt: 15 jan 2007 17:59
Senest aktiv: 14 okt 2022 21:38
Mit fyr: Biomax 10 compact
Areal: 180
Geografisk sted: St.Ajstrup 9240
Re:
Indlæg af petaas »
Good that the burner runs again.
Many have had to soldering the fotoresistor. It is a known problem.
Mvh Peter Andreasen
Biomax 10 compact
milkyway
Tilmeldt: 22 jan 2007 13:51
Senest aktiv: 07 jul 2008 09:13
Mit fyr: Ikke udfyldt
Indlæg af milkyway »
petaas skrev:Good that the burner runs again.
Is there any FAQ on the internet, that describes the common problems with this kind of burner?
If not, should we make one - or is it not necessary, because of a only few problems?
petaas
Areal: 180
Indlæg af petaas »
This forum is a live FAQ, just ask - And we will answer
Mvh Peter Andreasen
Biomax 10 compact
milkyway
While searching for a sparepart foto-resistor i disassembled a 4 EUR nightlight from ikea (OSRAM made).
[img]http://pics.ts-audio.net/robthumb_LFH0190611.gif[/img]
there is a fotoresistor inside that has almost the same values as the one used in the scotte burner. i think with some adjustement in the scotte control box (hidden menu) it will work!
Senest aktiv: i går 18:36
Let us hear if You have succes with the project.
