Kender nogen dette firma
multimek
Tilmeldt: 22 dec 2006 19:37
Mit fyr: Multi
Areal: 170
Brændsel: Piller + Div
Dagligt forbrug: 12-15
Årligt forbrug: 5,5 - 6
Geografisk sted: vestjylland nord for varde
Indlæg af multimek »
Er der andre her inde der er blevet kontaktet af dette firma uden selv at havde taget kontakt til dem ?
Magdalena Rusek
Greenfield Polska Sp. z o.o.
ul. Struga 42
70-784 Szczecin
tel./fax. 0048 914636248
office@greenfieldpolska.eu
http://www.greenfieldpolska.eu
Mvh. Per A. Buch
Ved Asaa-Multi-Service.
Senest aktiv: for 8 minutter siden
Næh, hvad ville de?
Sælge træpiller?
nissen
Tilmeldt: 26 dec 2006 19:21
Senest aktiv: 10 feb 2010 13:10
Mit fyr: Ikke udfyldt
Geografisk sted: Gludsted, Midtjylland
Indlæg af nissen »
Jeg har også fået en mail fra dem...
De vil gerne ind på markedet... skal lige undersøges nærmere.
Regnede med at de evt. havde fået min mail fra Arno Eko? som jeg handlede med sidste år.
Mailen siger ikke så meget:
"16th February 2007
Greenfield Polska is a new producer of wood pellet on the Polish Market. We’ve just started commercial activity abroad and that is why we would like to present our product to you. We’re confident that pellets we produce will help you in your business. The pellet is in excellent quality with DIN rate of output. During one month we can produce more than 2000t in total.
The parameters of our pellet include: Origin:
chemically untreated wood without bark ,
Size: diameter 6-8mm, length max. 5x diameter ;
Bulk density at least 650kg/cubic meter ;
Moisture content no more than 8% ;
Ash content no more than 0,7% ;
Caloric value 19,5 MJ/kg;
No artificial additives
Only products from the primarily agricultural and forest biomass that are not chemically modified are approved to be added as a pressing aids.
We are ready to cooperate with different kinds of clients depending on the size of placing orders.We can offer briquette and firewood as well. If you require more information please don’t hesitate to contact me at any time.
Magdalena Rusek
ul. Struga 42
70-784 Szczecin
http://www.greenfieldpolska.eu "
All the best
/Nissen
Oakfarm
Tilmeldt: 18 jan 2007 21:33
Senest aktiv: 21 nov 2020 11:05
Mit fyr: BAXI mulitiheat 1,5-350 M. Iltstyring
Areal: 160(u-iso)+ 160L VVB
Årligt forbrug: 9 ton sidste sæson
Geografisk sted: På toppen af Sønderjylland
Indlæg af Oakfarm »
Ja, det kunne da være interessant at se hvad de kan tilbyde ..
Vi må håbe at der kommer flere producenter, så vi kan få prisen ned eller i det mindste stabiliseret (også i tilfælde af et par hårde vintre)
Mvh. Ole
Baxi 1.5 - 350
Kan de levere til en testafbrænding, kan det være interessant for indkøbsforeningen.
pillen
Tilmeldt: 04 jan 2007 19:22
Senest aktiv: 30 jun 2010 13:16
Mit fyr: Baxi 1,5
Areal: 150
Indlæg af pillen »
hejsa
Har modtaget en fra dem på min spam mail, men den figurere ikke nogen steder. så hvordan de er kommet i nærheden af den mail,aner jeg ikke...
Det lugter lidt.... måske lidt som de breve fra Afrika med en mand som lige skal nogle millioner ud..
Claus AKA pillen
dangman
Tilmeldt: 10 jan 2007 22:33
Senest aktiv: 23 apr 2007 12:56
Indlæg af dangman »
Ikke for at lyde for negativ, men hvis jeg skulle have noget ra det land vil jeg føst se varen og tjekke at den er ok før jeg betaler en klink. Mulighedden for at de prøver at sælge en vare som de ikke har er ret reel i mine øjne og den anden mulighed er at deres produkt er af en meget ringe kvalitet ! Jeg har stået i en produktions linie hvor vi i et par år fik "euro" paller ra polen, godaw det var engangs paller med et euro stempel på ! Så hvis de kan fuske i en årrække med euro paller så hvad kan de ikke med træpiller som ikke er styret i den grad !
Du har ret dangman.
Selvom vi får et par hundrede kilo til test, kan vi ikke regne med at det er samme kvalitet som hvis vi køber et træk.
Reklamationsmulighederne er nok ringe så man skal passe på.
dangman
Indlæg af dangman »
Det eneste mulige alternativ jeg ser er at man selv henter et træk med en sættevogn ! men hvem har lige den stående :o)
multimek
Mit fyr: Multi
Areal: 170
hej
Jeg har aldrig hørt om dem, eller støt på dem nogen som helst steder, synes ellers at jeg efter hånden har været næsten alle div. sider om brændsel i gennem :)
Jeg tror heller ikke jeg vil være videre glad for at ligge mine penge ved en ukent forhandler med en yderst tvivlsom vare !
Jeg tror også vi skal satse på en DK producent med gode solide piller :)
Mvh. Per A. Buch
