Version 0.5.0 has a new plugin
Onewire made for reading onewire temperature sensors using the kernel driver (like it's done in the privateeyepi project), instead of connecting to an owserver that takes care of the onewire hardware. This plugin only supports reading from temperature sensors supported by the w1-therm family driver, where the other onewire plugin
OWFS supports mostly any kind of onewire hardware.
The reason to use 'Onewire' instead of 'OWFS' is mainly that on eg. a raspberry pi the Onewire plugin + kernel driver can use a GPIO pin to connect directly to the onewire network (with the aid of one resistor), while using OWFS + owserver requires a hardware bus master, for instance a usb-dongle, which adds to the price of the setup.
Onewire plugin configuration:
https://github.com/motoz/PellMon/blob/m ... ewire.conf
Another new addition is
pellmonconf, a web based text editor for the configuration files, that simplifies editing the configuration files.
Kode: Vælg alt
$ sudo pellmonconf
Open http://<ip>:8083 with your webbrowser to view the configuration tool
Run as root to be able to save changes
Quit with CTRL-C
