Raspberry Pi
Juel
Tilmeldt: 16 mar 2011 21:49
Mit fyr: Scotte m. woody chip.
Fremviser gerne i postnummer: 4250
Geografisk sted: Omkring 4250 Fuglebjerg
Raspberry Pi
Indlæg af Juel »
Arhhh I have set the values now, and it Works :) Cool thanks :)
Ok, ill try an upgrade, maybe tonight :)
I'm gonna look into that fail2ban thing, I dont want ppl to turn off my heat :D
motoz
Tilmeldt: 14 feb 2013 08:06
Mit fyr: BioComfort 30kW + termax 25cr
Geografisk sted: Ostrobothnia
Blevet takket: 11 gange
Raspberry Pi
Indlæg af motoz »
When you so kindly shared a link to your system I noticed that you have added 'flow' to your graph. There is a new-ish feature in pellmonweb that makes it possibly to add a scaling factor and offset to selected graph-lines. By adding a offset:divisor of eg. 0:10 to the flow line it would fit in with the other lines.
from config:
[scaling]
# add optional scaling to the plotlines before drawing the graph
# The right axis will scale to match the scaled data, when there are
# several different scales in use it will match the first selected
# line in the order they appear here
# the offset is first subracted and the result is divided by the divisor
# dxx = offset:divisor
PellMon open source pellet logger at https://github.com/motoz/PellMon
Juel
Raspberry Pi
Indlæg af Juel »
Yep i saw that, and I'm gonna play with that to, but at first i just wanted it to Work. :) It's a nice feature, cuz the high numbers ruins the graph, so I'm really looking forward to that. :) Thanks for the hint ;)
motoz
Raspberry Pi
Indlæg af motoz »
I pulled in the websocket and 'live system image' changes to the master branch now as there don't seem to be any more problems to solve. The websocket module ws4py is now optional so installation is just as easy as before on rasbian where it is not packaged, but installing it enable live parameter view/event list and also makes the system image much nicer (no continuous polling needed). The wiki has updated installation instructions.
motoz
Raspberry Pi
Indlæg af motoz »
Pushed a new system image to master. These are fun to draw!
My system is a lot simpler without external hot water so I'm missing most of the sensors, but I suppose this is a common setup in Denmark?
Will probably include a couple of variants of these in the default install, and a way to point to your own picture will also be added. Any suggestions for the picture (missing/erroneus details or just the general look of it) would be appreciated...
epo
Tilmeldt: 29 jun 2008 22:12
Areal: 239
Årligt forbrug: 9 paller
Raspberry Pi
Indlæg af epo »
Jeg lavede mit eget lille system på en Beaglebone for at undgå at have en pc kørende. Burde sagtens kunne køre på r.pi også, hvis man har kørekort til linux.
Ckeck min fyrdata på http://37.75.172.9/
Det er lavet til en temmelig gammel version af Woody'en
Skrev et indlæg om det for nogen tid siden.
viewtopic.php?f=137&t=18530
bofrede
Tilmeldt: 30 okt 2014 10:39
Raspberry Pi
Indlæg af bofrede »
Jeg har selv en 16 KW Blackstar med v6.78 styring. skal jeg så forstå det at det er mulig at bruge en dims " MK802 " med android til at styre fyret med online på nette og så spare den computer jeg har til at gøre det med nu
motoz
Raspberry Pi
Indlæg af motoz »
Some googling shows that you could install ubuntu instead of android on the MK802 then both PellMon amd Epo's project will probably work fine. I'm not aware of anything made for android.
rydos
Tilmeldt: 30 okt 2014 10:15
Raspberry Pi
Indlæg af rydos »
My system running http://88.196.184.120:8081/
motoz
Raspberry Pi
Indlæg af motoz »
Great! Nice to see another PellMon in the wild!
If you want you can remove the unused lines from the graph by commenting them out from the [PollValues] section in the config file:
[pollvalues]
#d06 = oxygen
#d08 = smoke_temp
To customize even further, the nonexistent sensor readings can be removed from the system image by opening the image file system.svg with eg. inkscape and removing the corresponding text objects. There is a piece in the PellMon wiki on the subject https://github.com/motoz/PellMon/wiki/C ... stem-image
Tilbage til "Woody Pillefyr"
