Hello,
I have just moved to Denmark from England and bought my first house!
The house I bought has Solar Electric Panels and Solar Heating Panels for hot water. When we moved in, the system was working nicely, but now the Solar Heating panels do not heat up my hot water tank...
I have noticed two things:
1. The Sun-Comfort control box now says "Frostsikring" I think this means Frost Protection, but it is now 25 degrees outside and beautiful weather in Denmark.
2. On the pipes I have noticed that one side says 60 degrees and one side says 19 degrees, but I can hear the pump working.
I have attached some pictures.
If any super fantastic Danish person can help a new Brit then I would be very grateful!
I am not an expert with this type of thing just so you know.
I was not given any information about the solar panels and solar heating when I moved in...
Best regards,
Sam
New in Denmark - Solar Heating Question
- 5
- Tilmeldt: 21 apr 2019 13:37
- Stoker XI
- 5
- Tilmeldt: 29 mar 2019 18:14
- Mit fyr: Nbe 1016 kedel 10kw
- Areal: 140
- Fremviser gerne i postnummer: 6933
- Dagligt forbrug: 6 kg
- Årligt forbrug: 6
- Har takket: 384 gange
- Blevet takket: 108 gange
Re: New in Denmark - Solar Heating Question
You Can get help from stokerforum.dk , they have a forum for sunpanels. If it fails to get help here. Best regards
10 kw nbe 1016 kedel,140 kvm hus, murer af Guds nåde.
- John Skov Jensen
- Redaktør
- Tilmeldt: 02 maj 2009 20:40
- Mit fyr: Atmos DC40GD
- Areal: sammenlagt 350 m2
- Brændsel: Bøg
- Blevet takket: 440 gange
You have a Suncomfort control unit.SamL skrev: ↑21 apr 2019 13:51 Hello,
Best regards,
Sam
Here is a link to the manual
https://www.nbe.dk/wp-content/uploads/2 ... sion-6.pdf
Only available in danish apparently, sorry
As i see it, your absorber sensor in the top of your panels shows -99 degrees. That indicates a short circuit in the sensor or the sensor cable or "just" a faulty sensor
And this invalid input sets the control unit into frost protection mode
