Vaskemaskine
- Stoker III
- Tilmeldt: 21 jun 2013 22:14
- Senest aktiv: 30 sep 2014 06:15
- Mit fyr: Mgm 15
- Areal: 180
- Brændsel: Træpille
- Fremviser gerne i postnummer: 4800
- Geografisk sted: Falster
- Tilmeldt: 21 okt 2009 23:02
- Areal: 425 m2
- Årligt forbrug: ca 10 tons
- Geografisk sted: Holbæk
- Har takket: 1 gang
- Blevet takket: 136 gange
Vaskemaskine
Google er din ven :
F1 : Washing machine temperature sensor fault
The washing machine has detected a problem with the water heating temperature sensor and although the program will complete the machine will not heat the water.
Check wiring to temperature sensor or thermistor
Check thermistor or temperature sensor
Replace thermistor if faulty
Check heater
Check wiring at control module or timer
Google er din ven :
Check heater
