Og det er det originale kabel han bruger ? , kan se at mange har problemet med uoriginale kabler
sku godt nok mange der har lignede problem
Klippet fra andet fora :
have just been speaking to htc support on this matter on pc...................follow these steps it fixed mine and is charging normally now, well so far...........We will have to perform basic troubleshooting steps on your phone.
10:32:41 [gayle] :
ok
10:32:51 [Rhoda] :
First let's do a soft reset to refresh your phone settings.
10:32:57 [Rhoda] :
Please go to Settings.
10:33:15 [gayle] :
ok
10:33:23 [Rhoda] :
Then tap on Power.
10:33:34 [Rhoda] :
Unchecked Fast boot.
10:33:50 [gayle] :
done
10:33:54 [Rhoda] :
Then turn the phone off for 5 seconds and then turn the phone back on.
10:34:49 [gayle] :
done
10:35:11 [Rhoda] :
Please charge your phone and check if it still have the same issue.
10:37:39 [gayle] :
seems to be fine now, thank you why would that happen
10:37:50 [Rhoda] :
Great! Well the phone needs to be refreshed once in a while.
I've had all the problems mentioned in this thread and tried everything (all the solutions I've read in this thread and on the internet like cache wipe, resetting the charge mode, holding butons etc.). Nothing worked permanent. So i've also read about spraying contactspray (electronic connector cleaner) into the usb port to clean the port.
I taped my phone in to protect it and sprayed the contact cleaner into the port, waited a half an hour and tested it. I've repeated the proces like 3 times and saw some improvements, but still not perfect. So I went to sleep and since the next morning everything was working perfect again and still does. So I think the spray needs some more time to clean everything properly. I also rubbed with a needle to clean the dirt in the port, but I don't no if that is needed.
So it starts charging directly now when I plug my charger in, my computer recognizes the phone again, no usb host mode error anymore etc.
