Baxi Multihead doesn't start after security shutdown
tomdk
Tilmeldt: 21 mar 2009 11:03
Senest aktiv: 21 mar 2009 12:49
Indlæg af tomdk »
Hej,
undskyld jeg kan ikke taler dansk, herfra jeg skriver po engelsk.
I do have a problem with the heating system installed in my house. It is a Baxi Multihead although I do not know if it's a 1.5 or something else. After a security shutdown due to back burning along the conveying screw I can't restart the heating system.
I cleaned the pellet container and the burning cell, as well as the tube where the conveying screw is housed. So there is no tension on the conveying screw and everything is try. Since the fuse popped during the shutdown I would like to turn the system back on while activating the fuse again.
Every time I do this the fuse pops out almost immediately. Do you have any suggestions how to solve this problem?
Any fuses at the heating system to check or anything?
I appreciate all suggestions.
Thanks, Thomas
Jan_Al
16
Tilmeldt: 09 okt 2008 19:54
Senest aktiv: 24 aug 2025 17:15
Areal: 154
Har takket: 16 gange
Blevet takket: 7 gange
Re: Baxi Multihead doesn't start after security shutdown
Indlæg af Jan_Al »
There must be a dataplate on the unit somewhere. Try to locate it and write down the data here, then it will be a lot easyer to do some troubleshooting.
MvH
Jan
tomdk
Indlæg af tomdk »
Yes, you are right. Found it and it is a Multihead 1.5
Any more details you need from this plate?
Thomas
Jan_Al
16
Areal: 154
Indlæg af Jan_Al »
Is it the fuse in your house that pops or a circuit breaker trip in the unit?
MvH
Jan
tomdk
Indlæg af tomdk »
When I turn the fuse in the house back on, the heating system response with a sound from the electronic and some mechanical sound and then the fuse in the house pops out again.
Thomas
Jan_Al
16
Areal: 154
Indlæg af Jan_Al »
Try to locate the 2 contactors, K1 and K2, for the conveying screw. If the fuse blows when one of the contactors is activated, it is very likely that the motor of the conveying screw is faulty :(
MvH
Jan
Senest aktiv: i dag 00:36
Areal: 190 +værksted 130
Brændsel: Estonia
Dagligt forbrug: ca 8-30
Årligt forbrug: ca 5-6
Har takket: 105 gange
Blevet takket: 292 gange
Indlæg af thy »
hvor bor du..
try replace all 3 fuses... at the same time
