God dag,
First can I apologise to write in English... my written Danish is no so good.
My question, I have swapped out a Roca P30 kedel and have put in a Opop 16kw.
This has worked ok for a week now and saved 10kg a day in pellets!! I wanted to see how easy it was to clean and shut the burner down in the normal way. I cleaned the kedel and also move the electrical supply to the control box (Woody) and pump as the unit is going to mounted on the wall in a different position from before. Due to way the cables were run in the room I had to disconnect the cable from the Woody control box to the burner. I made a note of the way they were connected and replaced them in the same way. When I fired up the Woody control box the burner made a buzzing noise (50hz mains) and then knocked the power out at the fuse panel. I checked my connections again and used a meter to make sure they were connected to the right pins on the plug on the top of the burner unit. Checking an Installation PDF file, NBE Wood Pellets Burner Bio Comfort, that I down loaded from the Net. This appears to be the only one that is available so I assume that this is the correct one. I noticed the colour coding of some of the cables connected to the two motors on the circuit board that is in the burner are not in the correct place to that shown on the PDF circuit diagram, but as it has been working ok in the past so maybe this is not a problem. I think the motor that turns the screw in the burner is a Phase Shift one, so could the condenser that is connected to it be the problem? So the motor does not see a shift in the phase and then does not turn, this draws a lot of current and makes the buzzing noise then knocks the fuses out. I think the blower motor is not the problem but I could be wrong of course.
I wonder if anyone has any experience with this type of problem as I cannot see where I have gone wrong.
I thank you in advance.
Fraser
