Er der andre her inde der er blevet kontaktet af dette firma uden selv at havde taget kontakt til dem ?
Magdalena Rusek
Greenfield Polska Sp. z o.o.
ul. Struga 42
70-784 Szczecin
tel./fax. 0048 914636248
office@greenfieldpolska.eu
http://www.greenfieldpolska.eu
Kender nogen dette firma
- Stoker X
- 18
- Tilmeldt: 22 dec 2006 19:37
- Mit fyr: Multi
- Areal: 170
- Brændsel: Piller + Div
- Dagligt forbrug: 12-15
- Årligt forbrug: 5,5 - 6
- Geografisk sted: vestjylland nord for varde
Mvh. Per A. Buch
Certificeret tekniker og supporter
Ved Asaa-Multi-Service.
co-Admin på Asaa Multi Services Forum
Hjemmeside: http://www.asaa-multi-service.dk/
- Stoker IV
- 18
- Tilmeldt: 26 dec 2006 19:21
- Mit fyr: Ikke udfyldt
- Geografisk sted: Gludsted, Midtjylland
Jeg har også fået en mail fra dem...
De vil gerne ind på markedet... skal lige undersøges nærmere.
Regnede med at de evt. havde fået min mail fra Arno Eko? som jeg handlede med sidste år.
Mailen siger ikke så meget:
"16th February 2007
Greenfield Polska is a new producer of wood pellet on the Polish Market. We’ve just started commercial activity abroad and that is why we would like to present our product to you. We’re confident that pellets we produce will help you in your business. The pellet is in excellent quality with DIN rate of output. During one month we can produce more than 2000t in total.
The parameters of our pellet include: Origin:
chemically untreated wood without bark ,
Size: diameter 6-8mm, length max. 5x diameter ;
Bulk density at least 650kg/cubic meter ;
Moisture content no more than 8% ;
Ash content no more than 0,7% ;
Caloric value 19,5 MJ/kg;
No artificial additives
Only products from the primarily agricultural and forest biomass that are not chemically modified are approved to be added as a pressing aids.
We are ready to cooperate with different kinds of clients depending on the size of placing orders.We can offer briquette and firewood as well. If you require more information please don’t hesitate to contact me at any time.
Magdalena Rusek
ul. Struga 42
70-784 Szczecin
http://www.greenfieldpolska.eu "
"16th February 2007
Magdalena Rusek
ul. Struga 42
70-784 Szczecin
All the best
/Nissen
/Nissen
- Stoker III
- 18
- Tilmeldt: 18 jan 2007 21:33
- Mit fyr: BAXI mulitiheat 1,5-350 M. Iltstyring
- Areal: 160(u-iso)+ 160L VVB
- Årligt forbrug: 9 ton sidste sæson
- Geografisk sted: På toppen af Sønderjylland
- Stoker IV
- 18
- Tilmeldt: 04 jan 2007 19:22
- Mit fyr: Baxi 1,5
- Areal: 150
- Stoker II
- 18
- Tilmeldt: 10 jan 2007 22:33
Ikke for at lyde for negativ, men hvis jeg skulle have noget ra det land vil jeg føst se varen og tjekke at den er ok før jeg betaler en klink. Mulighedden for at de prøver at sælge en vare som de ikke har er ret reel i mine øjne og den anden mulighed er at deres produkt er af en meget ringe kvalitet ! Jeg har stået i en produktions linie hvor vi i et par år fik "euro" paller ra polen, godaw det var engangs paller med et euro stempel på ! Så hvis de kan fuske i en årrække med euro paller så hvad kan de ikke med træpiller som ikke er styret i den grad !
- Stoker II
- 18
- Stoker X
- 18
- Mit fyr: Multi
- Areal: 170
hej
Jeg har aldrig hørt om dem, eller støt på dem nogen som helst steder, synes ellers at jeg efter hånden har været næsten alle div. sider om brændsel i gennem
Jeg tror heller ikke jeg vil være videre glad for at ligge mine penge ved en ukent forhandler med en yderst tvivlsom vare !
Jeg tror også vi skal satse på en DK producent med gode solide piller
Mvh. Per A. Buch
